GeorgiaVOL
- 3:13 AM
- Nov 30, 2016
- Columbus GA
I have a used OEM 3120 crank if someone needs one. $75 plus shipping. Thanks!
Chainsaw. I'll snap a picture tonight
I think the chainsaw and demolition saw cranks are the same, except for some of the demolition saw
cranks have a hole in the PTO stub shaft to allow excess oil from the crankcase to seep through to the
bearing for the drive drum (i.e. clutch drum).
I have two cranks here, one from a chainsaw, and one from a demo - both have the same part numbers
on the lobe but one has the hole and the other doesn't.
They must have used those cranks in a few chainaws too....I had a customers basically new (2017) 3120 here that was failing pressure test....It was leaking out the lube feed hole to the drum brg.
I think so Rob - I tore down a 2006 chainsaw and it had one of those cranks...I couldn't get it to hold a tune after the complete rebuild.
It was very frustrating until I traced back where the hole came from. I plugged it with Yamabond and life was good after that.
