brushwacker
- 6:23 PM
- Jan 18, 2017
- NW IN, USA
272xp bought at county auction. It looked like it sat a while in a dirty environment. I blew it out with compressed air, did not take the sidecovers off so it would be advantageous to take off the starter cover and blow out the crud under neath yet. I drained the old fuel and put in fresh non ethonal mix with a drizzle of seafoam for its first round. Did blow out the air filter, removed the spark plug cleaned and gapped. Has good compression, starts, runs, idles. I cut about 25 minutes dead white oak, worked fine. It does leak gas when on its side and over 1/4 full. It sounds like it could use a little richer adjustment on the low speed screw but will need pull the limiter cap the way it felt. No other known issues but that doesn't mean for sure there isn't. Comes with a 20in bar and chain I'd guess 30 to 50% life left.
Price as is $265. + the ride. If it doesn't sell soon, i intend to fix and finish cleaning it up and adding to the price.
