Husqvarna 234se piston options
wcorey
11:25 AM
ma usa
Picture got cut off, near the bottom shows part # for a 133 piston which should be the same as a 234.
The stated spec of 12mm from pin to top seems suspect...
Agrarian
11:25 AM
New Hampshire
Yes, 133 and 234 are the same.
501625302 - Grade A
501625303 - Grade B
501625304 - Grade C
It takes a 10mm dia x 25mm pin and uses a Mahle 38ZN7 cylinder (maybe others?).
