Just an fyi, that's a Husqvarna 1100 wrap handle in the picture.
Also, the Pro Safety version came with a rubber wrap just the like 2100 wrap. The only real difference between a Pro Safety wrap and the oe is the PS wrap is ~1/8" or so larger in diameter than the standard 2100 grip, and the upper clutch side corner is rounded as opposed to being a sharp 90 degree bend. It'll look exactly like the PS 395 wrap shown below, just scaled slightly different. Dimensionally I don't believe the PS wrap is "oversize" compared to the oe.
Any particular reason you want that handle as opposed to the factory full wrap?
I have a nos pro safety with the rubber but they supposedly also made the “HD” which is the one pictured and kicks the saw up higher to run the large bottom tooth dogs
That would be awesome if they did, my 2100's front handle has been around the block a few times and I don't want to pay $100+ for another well used handle...
