Husky 576 Autotune Repair
Brewz
11:58 PM
Hunter Valley - Australia
Hi Folks
I have a 2010 Husky 576 Autotune here that I was told had cactus poison mixed with the fuel in stead of oil.
I just got the top end off and the piston is scored up at the exhaust port but the rest of it looks ok.
N0t much oil in there but a little bit, ebough to keep the bearings nice.
Perhaps it shut down before it had a complete meltdown?
Found some nice buildup in the carb
Anyway, I have a few questions for the Husky heads out there.
1. Will 372 crank seals fit this saw?
2. Can someone in the USA get me a price on an OEM piston? They will be $200+ here in Oz
I bought a "quality aftermarket" piston from HL Supply and it turned up as a Golf :(
@Gentleman , would it be possible to have these pistons listed with their brand when known? and while I have you, can you sell an OEM piston on its own as I notice you have full OEM piston/cylinder kits listed.
I will be able to fix the cylinder... blame @Mastermind haha
The transfer cutouts on the Golf are different by a LOT and will dramatically alter the timing
It is also over 12% heavier
OEM @110g
Golf @ 124g
Check out the height difference of the lower cutout's top edge and the size of the top slot.
Its not even close.
Its a paperweight considering this saw is a business owned working saw.
Marshy
WFO Cutting
7:58 AM
Mexico NY
I beliwve the clutxh side bearing has an integrated seal. You cannot simply use a seal from a 372xp. That bearing is rather expensive.
Crzybowhntr
Apprentice Slacker
7:58 AM
WV
@Brewz , I may have the block of plates needed to do pressure/vacuum tests. If you need them and I still have them, I'll send them out to you at no charge.
Marshy
WFO Cutting
7:58 AM
Mexico NY
Hi Folks
OEM @110g
Golf @ 124g
Its not even close.
I thought I read the upper slot in that piston isn't used for porting fuel in the cylinder. Some things I read concluded it was for weight reduction. I have not confirmed any of that though. Maybe so some knows the first hand and will chime in.
awol
6:58 AM
Cabool, MO.
Don't be scared to use that Golf piston, I installed one last summer in a 576 for a local crew, and it runs every day. The top cutouts in that piston are only for weight reduction, they don't play a part in scavenging. The only way to check strato timing is to slide the piston up in the bore, and observe the ports opening. Mine was identical to an OEM in timing, but I did do a lot of grinding to change it to what I wanted.
Brewz
11:58 PM
I can get an OEM piston for around $65. Let me know if you want me to order it.
I'll credit you for the Golf if you don't want to use it.
I respect awol's experience so I will use the Golf. If the top slot is for weight reduction only I will put it on a diet.
@Gentleman thankyou for the kind offer but I would only ask you for credit if I could send it back.
I will give the golf a go.
Brewz
11:58 PM
Managed to take several grams out of the piston.
It's now only 4 grams heavier than OEM with most of that in the thicker walls.
I will be shortening the OEM wrist pun also as it's 25% lighter than the after market pin
mdavlee
Hillbilly grinder
7:58 AM
TN
mdavlee
Hillbilly grinder
7:58 AM
TN
Muffler mod and I think the up 1mm and down 1mm is all that was.
awol
6:58 AM
Cabool, MO.
Some of them have room to drop the base gasket, that wohld give you 1mm down for the intake. They do reallly like a wide open muffler.
The grinding you did on your piston looks real similar to what I did.
