HELP! Husky 55 Cylinder Decomp. Valve Assembly
Mooselegs
OPE Member
11:33 PM
Langley, B.C.
Could anyone let me know if there is any real Difference Between an OEM Decomp. Valve Assembly for a Husky Model 55 (1991 Year) c/w: 46mm Cylinder Assembly & an Aftermarket one? Also, I have read quite a Bit these Decomp. Valve Assemblies are Not that Great so if not, What is Required to Plug the Threaded Hole in the Jug/Cylinder Thread Wise and is there a Copper Squish Ring/Seal Required?
Woodwackr
12:33 AM
ID
Plugs are available all over. I get them on ebay.
hacskaroly
2100 Fanclub Member
11:33 PM
Northern Idaho, Ehh
ammoaddict
2:33 AM
Granite Falls, NC
I( have a 55 with no decomp it has a place for it but it is not drilled thru nor threaded.
I wish it had the decomp, it's got 180 lbs comp. and it pulls hard.
I have one too. I've thought about threading it but haven't. It's hard on me to start it. I have a bad wrist.
Boogerblaster
Active OPE Member
1:33 AM
Tennessee
I'm a machinist and any job shop should be able to install a decompression valve for you. They will need the valve at the time of drilling and tapping so they'll know how deep to tap the threads.
Huskyvarnya Saws
1:33 AM
Alabama
I have the decomp plugged on my 55. For a saw of that class I would say it is harder to pull over than average. I don't mind it being plugged though. My dad, who is now pushing 60 doesn't care for it at all.
Huskyvarnya Saws
1:33 AM
Alabama
I recently built a 288 with no decomp that is a bear to pull over. I was wondering if anyone had ever had one tapped by a machine shop. The cylinder casting has a spot for one, it just isn't tapped.
old guy
Love me some Husqvarna
1:33 AM
Becker Minnesota
Yeah. I could drill & tap it myself, I have valves.
I took this saw on trade, I really don't need it. I am 84 years of ancientness and have plenty of easyer starting saws.
old guy
1:33 AM
Becker Minnesota
I had a like new 281 with no place for decomp, that was too much, it had to go to younger person.
Huskyvarnya Saws
1:33 AM
Alabama
This is the first saw I have encountered that I couldn't drop start with relative ease. If my boot would fit though the handle, starting it from the ground would be more manageable. But since I can't fully secure it with most of my weight, that is a major pain in the ass as well. Which is why I'm going to see about getting the cylinder tapped for a decomp. It would just make using the saw a much better experience as it runs and cuts great.
I had the bright idea of deleting the base gasket when I built the saw. In hindsight, that was mistake, although I'm not sure how much of a difference it would make. The squish was around .0025 if I remember correctly.
hacskaroly
2100 Fanclub Member
11:33 PM
Northern Idaho, Ehh
My foot generally does not fit in the handle either, I have adapted to putting my heal on the handle base plate instead when I can't drop start the saw. I can securely hold the saw in place that way.
Huskyvarnya Saws
1:33 AM
Alabama
I appreciate the suggestion, I'll have to try that! When the saw is hot I can drop start it, but that cold start is brutal.
KellyJackson
Need Husky 65L Parts/Saw
11:33 PM
Abbotsford ..
I Realize that there are AM Decompression Valve Assemblies however my Original Cylinder didn't have a Decompression Valve or Hole for one in the Cylinder Head. As I Purchased a New Aftermarket Cylinder and Piston Assembly the New Cylinder Head came with a Threaded Decompression Valve Hole/Port and if there is an OEM Part # for the Correct Decompression Valve Assembly this Information would be Appreciated so that I have some back Up Information when Ordering this Valve Assembly complete with Sealing Washer or Ring. Also, I would like to have a Threaded Plug & Seal so if someone could tell me the Appropriate Plug (Bolt) Size, Bolt Thread & Pitch this would also be Appreciated.
KellyJackson
11:33 PM
Abbotsford ..
My Model 55 is a 1991 Model Black Top & as the Top Cover did Not come with a Hole on the Cover for a Decomp Valve, will there be Room for Just a Plug and Seal to be Installed without Interfearing with the Top Cover as Oroinnal Cylinder Head Did not ave a Decomp Valve
ammoaddict
2:33 AM
Granite Falls, NC
The decomp on a 55 is on the side of the cylinder. It doesn't go through the top cover.
singinwoodwackr
12:33 AM
moon
These decomp valves are all pretty much the same. Husky seems to like blue, Stihl, black. They are all m10x1.0
Also, as stated, there is no ‘seal’ or gasket on these other than the same type of crush washer that spark plugs have.
