HELP! Husky 395 tank leaking
ErnieG
2:05 AM
Northeast PA
So I picked this husky 395 up as a project knowing it leaked gas ..come to find it must have took a shot and the limiter screw went up threw the handle slot .
What's your thoughts on repair ?
I was browsing some YouTube vids and found a crazy glue/baking soda repair that seemed to work good .
Anyone ever use this method ?
Or maybe try and melt it back together?
Jb weld doesn't seem to be a good option for longevity....I'd rather try a repair before buying a new tank first .
Thanks
Ernie
chiselbit
11:05 PM
Norcal
That’s what I tried, started with a pinhole that wasn’t really visible, ended with a hole big enough to stick a pencil into. Decided my plastic welding abilities suck and jb welded some window screen on it. Seems to be holding,, it’s on the oil side so maybe I’ll get lucky.
ErnieG
2:05 AM
Northeast PA
I tried welding it back together and it's not working very well ...I used a piece of plastic from a junk 372 cover I had lying around.
Wants to just keep weeping
I'm thinking I'm gonna be in the market for a replacement
Ernie
qurotro
Cookie Cutter
1:05 AM
Ar
Ernie
I think you didn't weld it deep enough to mix the tank and the added plastic together? It's like welding steel you need a pool of molten material and.. Well, I'm not a good welder.
Shane¹
2:05 AM
Kentucky
The jb weld tank weld sticks to plastic pretty well
davidwyby
Rural desert logging
11:05 PM
Extreme Southeast CA
This. A chunk and a tank will be hard to melt together. Try with trimmer string. Make sure the two plastics melt together…some plastics don’t jive with others.
ErnieG
2:05 AM
Northeast PA
Well after a few more attempts I was able to get it sealed up .
I had to get rite down in there as suggested and work my way out with a doner piece of plastic from a 372 cover using it like a welding rod to build it back up ....worked great 👍
I appreciate the help !
Ernie
