Husky 357 bearing depth. Uh oh...
Wagnerwerks
7:42 PM
Pa
I just realized I installed the bearing in the case first and it's not against the crank lobe. Will this be ok? Not sure why I did it this way. I put this bottom end together years ago... the seals are already in or I'd drive them in farther. 14791760241081787569307.jpg 14791760505031548516719.jpg
Wagnerwerks
7:42 PM
Pa
359 crank. No stuffers. I have 3 other bottom ends here. Two are like this, one has bearings against the crank.
Tor R
Novice, Leg model #2
1:42 AM
Mandal
weird , oem crank on all three?
My 357 cranks has extra space(crank has diff diameter also compared to bearing diameter) for carrieng stuffers.
Chainsaw Jim
Con Artist LLC
4:42 PM
Springfield Oregon
It seems like it would egg out the case easier with half the amount of support for each bearing.
Tor R
1:42 AM
Mandal
Isnt those 357&359 cranks the same with 359 comes without the stuffers but stuffers can be mounted?
Wagnerwerks
7:42 PM
Pa
Yes
The bearings are fully supported but they u st aren't against the crank webs.
I built this bottom end the same time I built my other 357 but I just didn't remember it being like this so I figured I'd ask you guys.
I ported a 359 top to test. It's set up at 100, 116, 76 so I wanted to try it out. My box o 359-7 parts is getting a little rougher over the years...lol.
