HELP! Ht133 pole saw
Khntr85
3:31 PM
Indiana
Got a ht103 and ht133 pole saws in a group of saws I bought, the 133 motor runs but pole
Part is broke….i think parts are interchangeable just curious if anyone has worked on many because im sure ill have some questions lol…
EFSM
2:31 PM
Extreme southern IL
I’ve worked on quite a few Stihl pole saws over the years, but mostly 130’s and 131’s. I pretty much have to relearn each time, because they usually come in disassembled because someone else had them apart and couldn’t get them together. They’re far more complex and finicky than Echo’s Power Pruner, which makes sense since Power Pruner was the OG of pole saws.
hacskaroly
2100 Fanclub Member
12:31 PM
Northern Idaho, Ehh
It has been a while since I have assembled those, but you might want to check, the inner shaft may be different (different mating heads or shapes). If I remember correctly its not as easy as just swapping poles (but then I could be remembering wrong). Stihl doesn't really like people mismatching stuff to make things work better or save some money. Some things have square pegs and others have round holes so you can't easily match them up.
singinwoodwackr
1:31 PM
moon
Which is why a friend’s tree service has dumped their Stihl’s for Echos. Half the price and easier to work on…and, parts show up at the dealer in 4 days.
I tried repairing a couple of his 131s. You really need a 20’ flat table to work on them.
Junk Meister
2:31 PM
Nebraska
I put a 131 motor on a ?101 non telescoping pole no problem with the fit
Khntr85
3:31 PM
Indiana
Once I tear into it I’ll let you guys know got a ht133 motor that’s good and I think the pole, but don’t know in sure it needs tore down and cleaned, the pole that is
16TAF
3:31 PM
VA
I have a landscaping business and Echo equipment just flat out works, and it doesn’t die. Although not as powerful as Stihl. I’ve got several of their SRM 225 weed eaters and one has been running for at least 7 years with nothing more than filter changes. I had to replace the purge bulb line this year. I just started it up yesterday for the first time since October, it started on the 2nd pull.
Khntr85
3:31 PM
Indiana
I just got these in a group of saws I bought so I want to get one running eventually to use around the house…
EFSM
2:31 PM
Extreme southern IL
Stihl hasn’t had a 21cc trimmer offering for decades. You should be comparing a 2620 to a 91 or 94.
Duane(Pa)
It's the chain...
3:31 PM
Centre County
I put new lines on my dad’s Echo. Pulled my guts out until I turned the damned thing on 😆 Stihl has momentary switch. Omg I can’t believe I did that!
hacskaroly
2100 Fanclub Member
12:32 PM
Northern Idaho, Ehh
Husqvarna's have the same thing and many people swap them out with the momentary kill switches just because they keep forgetting...like me, but I haven't gotten any of those switches yet... 🤣
