How The Hell Do You Use This Case Splitter?
bulletpruf
6:49 PM
San Antonio, TX
Ok, so I have an 076 Super that needs bearings changed, so I have it stripped it down to the bare case and I'm having a hell of a time splitting the case with my normal splitter.
I have this other splitter that I bought several years ago, but damned if I know how to use it. Anyone familiar with this?
Thanks
bulletpruf
6:49 PM
San Antonio, TX
Gotcha. I've never had any problems getting them back together. May just have to buy a new splitter; the one I have is worn out.
Kiwioilboiler
346 Pic Examiner
6:49 AM
Marsden Pt, NZ
How do you use a soft-faced hammer?
Heat up around the bearing pockets, I think 250F or thereabouts is enough but I'll be corrected for sure if I'm out, and then (assuming all the case bolts are out - don't assume) if you rap the end of the crank with the hammer while holding the case with a gloved hand the bearing should slide out of the heated expanded case pocket. Repeat on other side. Plenty of vids about if that didn't read clearly enough.
PA Dan
12:49 PM
White Oak PA
For me when not using a case splitter I heat up to break all the 25 year old stuck together parts. When I tap the crank the bearings almost always stay in the case. Then I heat the case up around the bearing and tap it out.
bulletpruf
6:49 PM
San Antonio, TX
I have a new splitter on the way, but I'll try this tomorrow. Thanks!
bulletpruf
6:49 PM
San Antonio, TX
For me when not using a case splitter I heat up to break all the 25 year old stuck together parts. When I tap the crank the bearings almost always stay in the case. Then I hear the case up around the bearing and tap it out.
Parts are close to 50 years old, I think. This probably rolled off the line in the 70's.
Ticked off at myself, too. I've rebuilt 4 or 5 of these, and the last time I didn't split the case and change the crank bearings, same thing happened -- they were noisy when I started it up after a rebuild.
bulletpruf
6:49 PM
San Antonio, TX
Well, I ordered a new case splitter, but turns out I didn't need it. Heat on the bearing pockets and a whack on the crank with a soft hammer did the trick.
New SKF bearings and OEM crank seals are in. Saw is about 75% reassembled. I'll finish it up tomorrow.
thanks again for all the input!
Scott
Gullet
11:49 AM
Arkansas
So basically the splitter turned out to be a putter back togetherer that lead to a another splitter?
And I wonder why I drink!
