Woodslasher
Teh debil
- 10:38 AM
- Mar 18, 2021
- Commiefornia
I was beginning the teardown of my 372 xpw when I noticed the flywheel had a crack under a recoil pawl. I assumed it was caused by the same thing that busted the fins, but the more I dug into it, the worse it got. The WTF is the friggin flywheel's warped! How in the hell do you warp a solid chunk of aluminum this friggin badly!? The one case bearing is also shoved out of its pocket into the crank. At this point I'm thinking about getting a donor case half, flywheel, coil, and crank. What do y'all think?
