How do I fix this cylinder.
Likesaws
3:02 AM
South west. Virginia
IMG_1281.JPG IMG_1280.JPG Got this cylinder off eBay cheap. What should I do to the pitting below the port in center. Plan on doing a little more clean up with the sand paper treatment. Not sure what to do about pin holes. Leave them alone or fill them with something? If so what?
Likesaws
3:02 AM
Going to see what happens. Going on a parts saw that had a bad top end.
Won't spend to much time on it though.
Any other opinions welcome.
Thanks
3:02 AM
Slide a piston up in it and feel for anything hanging it up. Nothing you can do about the lines up high. They'll cost you 5-10 psi in compression.
Make sure nothing protrudes into the bore in that spot under the exhaust and it'll probably last a long while
Likesaws
3:02 AM
Make sure nothing protrudes into the bore in that spot under the exhaust and il probably last a long while
Feels smooth by touch, will slide piston in without rings first see if it catches anything.
3:02 AM
Make sure those grooves on top don't have any ridges coming out. They probably do on both sides.
Take a small diamond ball and run the length of them.
Then polish the entire cylinder with a brake home and then scotchbrite.
You'll never make a silk purse outa that sows ear, but you'd be suprised at what will run and still make good compression.
On this jug, with the permission of the new owner, I smoothed the damage (groove) with a diamond ball. The darn thing makes the same compression it did before the damage.
Wagnerwerks
3:02 AM
Pa
That doesn't look much different than the old McCulloch jugs with the v cut in the port.
Likesaws
3:02 AM
Use stihl ultra. The carbon it produces will fill the gouges in. :dancer2: :godsdrink0nw:
Thought about 32-1
Will clean it up good see what happens
Thanks
