Farmchuck
The little S clip won't do any good on these saws, the loops in it are for the bar studs to go through and take up space on a bar that's too big for the studs.
I took the little square thing off & it appeared to be in correctly, the other side is rounded & wouldn’t fit in the bar. One thing I did notice was that the chain tension adjustment screw moves back & forth loosely in the saw housingCorrect or the projection is worn off from use through the years. Mine was missing altogether, The projection uses the cutout on the original bar to grab and move it along. Mine was using a new bar that had nothing except the end of the bar's stud slot. Surprisingly, that slot was just short enough to work with the part I fabricated in the shop. You just have to be sure that the projection protrudes out no further than the thickness of the bar.
