Homelite xl500 starter repair
LAWN BOY
Pothole
12:10 AM
Merrill, WI
Looking at one of Leon's YouTube videos, it appears I'm missing at least one piece from this starter assembly. It's an XL500 but should be the same as an xl12 or super xl ao. Can someone with experience with these recoils tell me what exactly I'm missing if anything? Thanks in advance. 1000000644.jpg
hacskaroly
2100 Fanclub Member
12:10 AM
Northern Idaho, Ehh
Did you take the spring out and clean that area? I have found with all of my McCullochs and Homelite they needed the entire assembly taken apart and cleaned out...lots of gunk in there. I had to really scrape some crap off of the spring. It works MUCH MUCH better when it is all cleaned out and lubed back up!! I am working on my McCulloch 200 recoil right now. I had to take a dremel to it to knock off the hardened gunk and metal rot. Its looking really good right now, even having to rebuild some spots with JB Weld. Everything moves easily now!
Like @BDSAWS stated, it can be tricky to get the pully back on the spring. Luckily the end of your spring is still intact, but it does take some practice and patience to get it back on.
LAWN BOY
Pothole
12:10 AM
Merrill, WI
My goal was going to be to leave the spring alone and only install new rope, in hopes to avoid dealing with the spring, as I hate them lol...
92TRX300FW
3:10 AM
Quebec,Canada
the hole for the pull cord is made for this put the pulley on the shaft and with a small pick and push the spring outward and the pulley should slide on
hacskaroly
2100 Fanclub Member
12:10 AM
Northern Idaho, Ehh
Hah, my McCulloch pulleys don't have that hole, its just hunt and peck trying to drop it on the end of the spring...that hole would definitely make it a lot easier!!
