Woodslasher
Teh debil
- 3:53 PM
- Mar 18, 2021
- Commiefornia
Up for sale is a Homelite Super 1130G. Not much backstory on this guy, my brother acquired it from a friend as a companion for his 1020 and has decided he no longer needs it. I put a carb kit in it about a year ago when he got it even though it was a runner since it has the single-jet SDC in it. It sounded a bit lean when I made a test cut with it so I only ran made 1 cut with it (it didn't sound bad, it just didn't 4-stroke out of the cut that I heard). Only bad thing with it is the muffler guard is cracked in half. All the pieces are present and it could be welded, but it is cracked in half and has a separate crack on the top. It'll come with two bars and chains, both the bars and chains are 0.63, one bar and two chains are .404 and both bars have the same driver count for the chains. The roller nose bar is kinda "fragile", the tip was stuck when I got it but it came loose with some oil and a few taps, I'd only use it for displays or a few cuts. The Windsor is what came with the saw, it appears to be in good working order. I have no clue on the price, how's $750 + the ride sound?
