red dawg461
Howdy y’all. I‘ve come to seek help from the pros here. I just can’t figure it out.
I’m bringing back to life my dad’s old 034AV, which I think dates back to the early 80s, and just can’t figure out what IPL parts to use. I’ve located a few 034 manuals on various sites and it looks like parts changed with the 034AV and I’ll be honest it’s really hard to figure out the Stihl parts list wit’s all the symbols and letters. All I have is the Serial Number that may give you an idea what year this may be: 1-39-152-83X, and from various parts dealers online this is an “early”model.
I put on a new rim sproket kit, 1125 007 1041 and it came with a drum with the numbers 1125 169 2902A, which is the oversized spline compared to the small spline that was original and wore out completely. I also added the cover washer on the inboard side of the clutch itself, as it was not originally pn the saw but the IPL showed it as a part I needed. Changed the clutch sprigs too.
The issue I had on my first test with her is the chain never did quite stop turning and the E-clip and outer washer, 27mm, appeared to be putting pressure on the drum itself and possibly the needle cage. Needless to say that after a few minutes the bearings literally flew out of the saw and my fun was done.
Is it possible that the washer that is on the inboard side of the clutch, perhaps to keep the oiler pump and crank bearing protected was not meant to be on this saw, which causes the whole clutch assemble to be under pressure by the E-clip and washer?
I hope that someone on this great forum has come across this before and can give me a hand in getting the right parts. Unfortunately the Stihl deals in my neck of the woods are parts changers and look at me like a deer in a headlights.
Thanks for your help y’all
RedDawg461
RedDawg461
