Dingeryote
- 1:42 PM
- Mar 4, 2016
- In the Blueberry patch
Went and pulled one of the Banjo trash pumps out, to drain a field this morning.
Got it fired on ether, and then nothing.
Swapped plug, spritzed out carb, wired the main jet, etc..
Nothing. Wont even pop on ether.
Check for spark...nothing. wiggle switch, polish up ground contact..nothing.
First trouble I have had with this one in 6 years, or HARD use.
Is there a common ignition gremlin with the GX 160, anyone is aware of?
Dang thing was running fine when it was put up.
