Gun range 2022,2023,2024,2025,2026
lehman live edge slab
Live Action
9:50 PM
Mn
My 94 carbine has always liked 170 grain best, super X specifically, corelockt is good too.
It doesn’t group 150 grain blue box federal it patterns them.
Other brands of 150 isn’t horrible just 170 is better.
My Canadian centennial shot everything very well
Corelockt ammo may change now since the parent company of federal now owns them just so you know. Bought a box of corelock tipped and they shot to same point of impact as federal in that gun.
FergusonTO35
10:50 PM
Boonesborough, KY
Hopefully they will keep the ammo quality good. Over the last few years Thunderbolt .22's have gone from dirty blasting junk to excellent, at least in my guns. My bolt actions group them better than CCI in fact.
MS261CM
7:50 PM
PNW
Looking for a pocket holster but I'm not finding much...
In case anyone is interested... I sold my 686+ -6 and 20" Rossi 357 and picked up this and a 16" Rossi in 44m. Well... because.
The 686+ was a fairly strong 357 as the 7 round cylinders locate the index slots between the bores. Cylinder gap measured 0.008". The sights were ok but I changed the rear to a Bowen Rough Country for the large flat black plane. I changed the front to a black Dawson as I don't care for red insert front ramps. Most would have been fine with the Smith sights. I did have to change a set screw and ramp up spring preload to avoid light strikes on harder primers. I also had to pull the 686 apart and remove the machine swarf from the cylinder stop spring bore. In doing so I discovered that the threads were shallow in the center sideplate bore and that the screw was forced in and assumed a V profile. I never fixed that, just kept that screw with that bore.
Following that experience I immediately pulled the Anaconda down to clean out the machine swarf. There was none. Machining and attention to detail inside and out surpassed the Smith. Cylinder gap measures a tight 0.002". I did see a looser one at another counter so there can be some variability. The cylinder stop notches are off bore center but not centered between bores as in the 7 shot Smith. The cylinder is a large diameter even for 44mag and well over SAAMI length to accommodate heavy projectiles loaded long. The DA pull is absolute butter smooth and well lighter than the Smith with no light strikes, in about 150 rounds anyway. I like all of that. Issues? The SA pull was crisp at about 6 pounds. That's a problem. My admttably reworked Smith was about 2 lb and crisp. I felt that was a bit low so I worked this down to just under 3 lb. Next was the rear sight. The rear elevation adjustment was fine like anyone else's. Windage was not spring loaded, had about 1 turn of backlash and relied on a poorly located grub screw to hold setting. You can figure out what's wrong with all of that. I replaced the rear with a Wilson Combat of supposedly similar dimensions. The sight had to be bottomed to zero with light bullets. The revolver rotates upward more with heavier projectiles so that's a problem. I don't like red insert ramps anyway so I ordered a serrated black Harrison +.050" (0.230") front to allow room for adjustment. The OEM grips were rubber Hogue. Hogue rubber grips are actually plastic with stiff thin rubber overcoat. I don't think there's much flex there but they are shaped nicely. I'll find out shortly. The grips in the pic are Altamont. They were milled flat in the back and sharply transitioned to the side contour. They hurt without shooting. I softened that transition and refinished with polyurethane. They feel as good as OEM now. I'll see how they do on the next range trip. I am not expecting any surprises.
10:50 PM
These are like 400.00 locally
These are nice pistols I've shot a few of them.
SOS Ridgerider
Muffler Modded Member
10:50 PM
Central CT
FergusonTO35
10:50 PM
Boonesborough, KY
So I'm getting my Savage Axis .308 ready for deer season and I noticed the left side of the barrel channel is not really free floated, which seems to be a trend for Savage. I relieved the left side of the barrel channel so it free floats now. I notice there is a fairly significant amount of forend tip contact under the barrel. Would you say that is by design? Should I leave it be? This rifle has a wood stock and I'm wondering if temperature/moisture changes are going to affect point of impact. Or am I just over thinking it as usual?
Hoser
10:50 PM
Grey county Ontario
I had a gorgeous bsa 222 that someone had “free floated” it shot horribly.
A good friend of mine shimmed the forend for good contact/ support and that rifle is now a favourite for walking the fields.
If it shoots good now don’t touch it, I’ve yet to see an axis that shot poorly.
FergusonTO35
10:50 PM
Boonesborough, KY
Thanks. I haven't shot this particular Axis too much, but so far it seems as accurate as my older one is. I had to free float the left side because it drives me nuts to look at, not because of any functional problem.
10:50 PM
Soon the distributor says
No idea what soon means.
But this'll be my next .22
My friend swears by the .22 mag version he
Shoots coons out of tree's with it.
I gave my sister a tx .22 she loves it.
She has a taurus g2c that's been great.
She prefers it over the arex I was going to give her.
FergusonTO35
10:50 PM
Boonesborough, KY
Ok, I have officially found my new favorite scope. Burris Fullfield 2-8x35, $159.00 delivered from Midway. Regular duplex reticle, not the silly illuminated one. The one and only concern is the short mounting surface behind the objective but I'll just use a rail if I have to. I have larger Fullfield II's on three rifles and love 'em. Now Burris finally came out with a new compact version, I think some more of these are in my future!
FergusonTO35
10:50 PM
Boonesborough, KY
Anybody here ever refinish a plastic stock with Brownell's Aluma-Hyde? I painted the stock on my Mossberg 100 .308 with it last night. I degreased the stock and rinsed it with non-chlorinated brake cleaner and let it dry overnight before painting. From what I understand, Aluma-Hyde takes many days to cure properly but is one of the best aerosol finishes out there. One thing I noticed is that minor runs and drips seem to self-correct by gravity.
FergusonTO35
10:50 PM
Boonesborough, KY
I did a test fit of the Burris 2-7x35 on my Mossberg 100. Just as I suspected, the scope needs high rings if you are going to mount it with the objective bell above, rather than in front of, the front scope base. My Burris medium rings were a bit short. My Leopold PRW medium rings, which are more like medium-high rings, just barely cleared. And I mean probably .005-.010 of clearance. Its not a deal breaker by any means, but it is unusual for a compact scope to require taller rings than most. I did order an EGW rail so I can move the scope back farther than the two piece Weaver bases allow, hopefully I can shoot it soon.
FergusonTO35
10:50 PM
Boonesborough, KY
I'm thinking this particular attempt at painting a stock with Aluma-Hyde is a bust. After drying for three days, it is of a gummy consistency and I can scrape it off with a fingernail. Plain old spray paint would be completely dry by now. So, I'm thinking that my can of Aluma-Hyde is no good, I didn't shake it well enough, I applied it too thick, or I didn't prep the surface well enough. I think I will let it dry in the full sun all weekend and see if that helps, maybe Aluma-Hyde really needs some level of heat to cure. If not, all I can think to do is peel it off and start over using the lightest coat possible. If I don't get a good result by the time this can is empty then I'll just go back to good old Krylon Fusion.
SimonHS
3:50 AM
Yorkshire, England
I googled it. Looks like it can take two or three weeks to dry. Curing time can be speeded up by baking at 195 Fahrenheit or blowing it with warm air.
So it is not a lost cause yet.
Link to search results here:
10:50 PM
