Catfishclark89
- 6:52 PM
- Jul 9, 2023
- Glasgow, KY, USA
Seven dust piled on the hole works pretty good. But if you cam burn em out…do it.Have a big nest of ground hornets (like the ones pictured below). Thinking of dousing with gasoline after dark or early early morning. Any other tips or something else to use?
that would work and be fun as well. post up a vid of the bonfireHave a big nest of ground hornets (like the ones pictured below). Thinking of dousing with gasoline after dark or early early morning. Any other tips or something else to use?
Can you get this in an aerosol ready to spray? I use permethrin clothing treatment in the woods and works really well keeping the ticks offI like permethrin, it is oil an oil based insecticide and knocks wasps or hornets down. Once they’re sprayed that can’t fly. It degrades quickly after a couple weeks in the sun it’s no longer active or harmful.
I used to work in pest control and permethrin is what we would use to douse large nests and I never got stung once.
You can get it a tractor supply. https://www.tractorsupply.com/tsc/product/control-solutions-permethrin-133-32-oz
I believe the stuff you get for clothing is water based and a much lower concentration. I use the stuff from tractor supply for spraying the yard. It’s oil based and I think it's 10% permethrin. IIRC, the sawyer branded stuff I use for clothing is 0.5%.Can you get this in an aerosol ready to spray? I use permethrin clothing treatment in the woods and works really well keeping the ticks off
I second this.Thinking of dousing with gasoline after dark or early early morning.
Good tip. I’ve got a red headlight I use walleye fishing.Some drain oil down the hole. I use a flashlight with red cellophane over the lens and never had a problem.
Yeap, common knowledge, wait until well after dark and hit'em with the gasoline.Have a big nest of ground hornets (like the ones pictured below). Thinking of dousing with gasoline after dark or early early morning. Any other tips or something else to use?
Drip from a natural gas reservoir tank will kill everythingHave a big nest of ground hornets (like the ones pictured below). Thinking of dousing with gasoline after dark or early early morning. Any other tips or something else to use?
