Krooza
Active OPE Member
Hello, soon i am rebuilding the engine and gearbox on my 1978 Gilson chain drive tiller. I am starting with the engine. It was run on low oil by a previous owner. I had it working and i was using it for a bit, but it smoked like a freight train and i was planning to rebuild it soon. The last time i started using it it suddenly started making nasty noises, so i shut the engine down ASAP. The conrod bolts had come loose. I am going to rebuild it now, since it was needing it anyway. I am replacing the rings, all seals and gaskets, conrod and bearing cap, and the cam, and lap and adjust the valves. When i get to the rebuild i will document it in this thread.
This is actually my first engine rebuild, however I am not new to working on engines and equipment.
So my question is... Is there anything i need to know before the engine rebuild? Do you have any tips or tricks? Thanks in advance.
