Genuine spark plugs
stretch5881
2:51 AM
Hatley, Wisconsin
As long as the plugs in Brazil are made to NGK specs, I will be happy with that. After all, the Stihl plant in Virginia builds their saws to German Stihl specs. Yes?
qurotro
Cookie Cutter
2:51 AM
Ar
B
Mines are made in germany, and WEST germany though.
Member
2:51 AM
B
The wall fell in '89 and reunified in '90. That would put them at over thirty years old. I only find one like that every once in a great while, in an old saw that someone tried a new plug in before giving up on it.
CR888
5:51 PM
Australia
There are two kinds of bpmr7a, I prefer the ones that don’t have the removable terminal on them. Both will work on a saw, but sometimes the removable terminal ones will have that part loosen from vibration or removing the spark plug boot. The unscrew-able terminal is more idiot proof. Also a lot of the newer bpmr7a are made in Brazil. I still like them, but the older made in Japan ones were longer lasting imo.
Totally agree! The removable terminal absolutely sucks in a saw/ope application. Always comes loose and when you grip them hard with pliers to tighten them you either snap it off, strip the thread or leave sharp jagged edges on the terminal. I hate them.
qurotro
Cookie Cutter
2:51 AM
Ar
Maybe press the removable piece to oval with vice then screw it in will help? I actually don't see them come off in a saw since the rubber boot and the spring inside won't let it.
deye223
AIR FUEL SPARK VROOOOOM
5:51 PM
Australia
Great news. I received the plugs today from HLsupply. They are NGK from Japan. Sure glad I ordered 2 shop packs.
My eyesight ain't what it used to be where on the plug does it say Japan on the metal part maybe
3:51 AM
Yes. The Brazil ones say nothing on the plug and Brazil on the box.
