SELLING Full wrap Jonsered 670 Super
Sawponder
OPE Member
1:30 PM
Virginia/N.Carolina
Full disassembly (minus case split)
New crank seals
Oiler oring and xring replaced
New OEM clutch assembly
New piston ring
New fuel lines
Oem tillotson Carb kit in and Carb passes pressure test and popoff is at factory spec
One of the air filter cover bolts is stripped, havent repaired yet
Fires right up. Idles great, oils good.
Chain brake Band has broken, but would work once replaced. Brake handle is missing
All oem saw
Can port cylinder and include pictures of the process for an extra $75
400 plus shipping
