Favorite semi skip chain
STOVE
6:12 AM
Eastern NC
Thinking about grabbing a 28” bar for my ms390, it’s got all the mods and some port work.
It’s for no real reason outside of not bending over a bunch. A 28 semi skip would have the same cutter count as my current 20” 72dl
What’s everyone’s favorite semi skip ? Should I go full skip?
Woodtroll
6:12 AM
Mtns of SW VA
If it's only for reach, and you're not planning on burying the whole bar, would you really need skip chain? (I'm sorry, I know that doesn't directly answer your question.)
Maintenance Chief
6:12 AM
South Carolina
Ms390 would definitely prefer the full skip. And I'd recommend Dukes brand chain in a cheap 3 pack.
The dealer is a member on this forum and I believe a sponsor. I've used plenty of his chain.
Traverse creek saw shop at the top of this page.
STOVE
6:12 AM
Eastern NC
I use his chain exclusively as is, I just wasn’t sure I wanted 3 chains for a 28”
hacskaroly
2100 Fanclub Member
3:12 AM
Northern Idaho, Ehh
I guess it really depends on the person. I have a MS 261c with a 20" bar that I run 3/8 .050 full skip on just because. From what I understand longer bars benefit from semi to full skip because there is less drag with fewer cutters compared to full comp chewing through the wood.
I also made a 31 driver 3/8lp .043 full skip chain for a 6" Milwaukee bar that mounts to a MS 170....just because 🤣
Junk Meister
5:12 AM
Nebraska
I read these kind of POSTS JUST BECAUSE I WANT TO. They certainly break the monotony and if I see that some one has done something then I can figger something else to do. :sun_smiley:
