weesa20
Hey Guys. I am looking into building a splitter from some parts I already have. Planning on a 24" in stroke.
What I have:
wedges
17.5 g/min pump
axle/tank- 5.5 gallons
multiple single spool valves
frame for the beam to sit on
Filter and mount
I am looking to build a wedge on beam machine. I have a twisted I-beam that came off a wedge-on-cylinder splitter that I think I can replace the I-beam and convert to wedge-on-beam.
Thinking about a HF predator motor- any benefit to move up to a 13 hp from the 9.5 hp that is typically used with this setup? Not sure I gain anything since I am limited by the pump I already have and would give up fuel efficiency.
Planning to use a 4.5x1.75x24 max 3000 psi cylinder, which is what was on the original machine. Any reason to change?
I would like to add an auto-cycle valve. Anything special needed there?
Dump valve? Any benefit with this setup?
5 gal auxillary hydro tank- 5.5 gallons is no where near enough, so I will need to add another tank...so I would just have fluid return to the aux tank and then gravity feed into the primary tank...sound ok?
Would like to add log lift and adjustable wedge in the future.
Thanks for any input/guidance.
W
What I have:
wedges
17.5 g/min pump
Filter and mount
W
