livemusic
- 8:23 PM
- Jan 22, 2016
- NW Louisiana, USA
Suffice to say, I have done everything I and advisors have said to do (except one... more later).
Short version... The mower suddenly quit while mowing. The only way I made it to my garage was huge amount of choke, even full choke. Ran very rough at times and would go dead. Finally did go dead again and wouldn't crank. (And did this many times after.)
Suspected bad fuel, checked it. Read 1-2% water. Disassembled carb and cleaned it. No fix. Determined that the fuel pump was not getting gas to the carb.
Checked all of the lines, all clear. Except, I did not check the short line from the fuel pump to the motor crankcase or wherever it goes, it's the impulse line. Too hard to get to, I don't even know how to get to it. However, if I put my thumb over the impulse line after disconnecting that end from the carb, I felt suction.
Somewhere along the way in here, I suspected bad gas again because that is what it acted like. I could get it going on full choke and then limp along with some choke down to not choke and such but it was often very rough.
I tested the gas again. This time, I read 5% water. Did I misread it first time?
I use e-free gas. I put in Seafoam at some point, which helped temporarily, which really confuses me based on this whole story. I also added octane booster on the advice of someone. Didn't work. I had wanted to add Heet and did after the octane booster didn't do anything.
Screw it... siphoned all the gas out of the tank that I could. But there was still gas in there, it's a multi-tiered tank, didn't get it all.
Installed a gravity feed nurse tank; the mower ran pretty much normal. Back to thinking it is simply not getting fuel.
Bought after market fuel pump, installed, no go. Bought OEM fuel pump, installed, no go. Bought another after market fuel pump, no go.
After suspecting fuel pump problems and not getting anywhere with all of this, my neighbor said "I'd just forget all about the fuel pump and install an electric pump; anytime the key is on, it's running, bypass the fuel pump setup." I was thinking that sounds kinda crazy, why wouldn't eXmark do that but I searched youtube and found a bunch of people do that.
So, now I am ready to do that but I want to ask... what is the negative? Is there any harm here? The fact the I have installed three fuel pumps and none of them work points me to the impulse line, something being wrong there. It could be a compression problem? But it ran fine on the nurse tank!
So, if I install an electric pump and just disregard what else could be wrong, and if it then runs, the fact that I really never did solve the issue, is this a bad move?
I am not anything close to expert, so, if this electric pump idea is bad or if I do it and it does not work, I will have to take it to a dealer and that means prolly $400 or more cuz that is what it always costs! I can do that but would rather fix it on my own. But, close to giving up.
Mower is ten years old, the motor has never given me any trouble. I do the maintenance. I have done repairs since I found out what the dealer charges, lol.
EDIT: Fuel filter was also changed.
