Mike C.
- 8:36 AM
- Jun 24, 2020
- New Hampshire
Hi guys,
I'm looking for answers to questions from someone who has actually worked on one of these trimmers.
My first question is:how does one remove the plastic plug blocking the high-speed mixture needle?
I was told by several that the plug just pulls out(with the appropriate tool),others say that the plug is threaded and one must unscrew it(hence the reverse threads on the removal tool).Does anyone here know the real answer-from experience?
Also,there are two different sized tools for plug removal-one is 2.5mm and one is 3mm.Which of these is to be used on this trimmer's Walbro WYG-9 carb?
Frankly,I might just use a machine screw to pull the plug or the hot screwdriver trick,but I' would like to know the correct tool.
Thanks.
Thanks.
