Shane¹
- 3:34 PM
- Dec 21, 2020
- Kentucky
Got 2 9010s I finally finished up going to see if there is any interest out there. Saws were missing pieces and I put them back together and got them running. Going to make 2 separate listings to keep the pictures separate but would definitely do a package deal on both. Both saws have a tillotson hs203 off dolmar 133 modified to fit. Only clutch cover I could find had front holes drilled so I drilled the other set. I only drilled one clutch cover so far so can have the one that's not drilled if you want to try to find studs and bar plates and run the other holes. Has a Stihl universal coil. I actually like the way they run with the Stihl coils this is the 3rd one I have put a stihl coil on. Inner spike is a cut out copy of the original. Runs good and oils like it should. Looking to get $500 plus shipping but open to offers
