Discontinued Stihl BR340 part name
craftydad
New OPE Member
10:51 AM
Schenectady,NY
Hi, This is a long shot but thot I’d ask. Awhile ago I brought my 20 yr old Stihl backpack blower BR340, to an authorized dealer for repair - it won’t start.
They said it needs a part that Stihl discontinued and are out of stock, so they can’t fix it. But, it’s possible some other place in the country might have it. They said the part name - a small part - can’t recall if it’s part of the carburetor or motor. It had a funny name I’ve never heard of before. P plug comes to mind but I know that’s not it.
Would anyone know part Stihl stopped making on the BR340? I’d rather not have to bring it in again just to find the part name.
Pete
legdelimber
10:51 AM
N.C.
I'm not a Stihl guy, but post any images you can and maybe someone who knows will pass through.
Some things are common enough to identify that there's a good chance someone will know what it is.
I see that you're a new member. Hope you like the place!
craftydad
New OPE Member
10:51 AM
Schenectady,NY
Pete
I found the receipt - it’s a Welch plug on the carburetor. I could replace the carburetor if I knew which one to get. At diyspareparts, it appears there’s a “HD-28D” carb and an “L WT-580” carb. Both say for the BR-340 backpack blower. Anyone know how to tell which one I have, or which one to buy?
jmester
10:51 AM
VIRGINIA
The carburetor will be stamped or printed with the model number on the body of the carb. Usually on the opposite side from the adjustment screws. Closer to the fuel pump cover.
BR 340 use either HD-28 HD-29 HD-45
BR 340L use the WT-580
All three of the HD series carbs use a K10-HD Repair kit. Which will have your welch plug.
The WT series carb use repair kit K20-WAT will also have the welch plug.
jmester
10:51 AM
VIRGINIA
Some pictures might help as well.
legdelimber
10:51 AM
N.C.
craftydad There should be a set of numbers stamped into the side of carburetor body.
Not my best photography, but take a look at these shots.
You can probably see the numbers where I circled them on the upper left corner of the carb body.
Your numbers should be different from mine though, as this carburetor is for some other piece of equipment and not a Stihl blower.
I believe jmester knows much more than me, as to what carb fits your blower.
Let me see if I can get a shot of the area where a typical welch plug would be located.
legdelimber
10:51 AM
N.C.
Craftydad Take a look at these images of a random carb from my treasure :rolleyes: pile.
While not your exact model again, hopefully, this will provide a basic concept of what you are looking to repair.
Image one- shows the identifier numbers "WA-134A" in the red circle.
Image two- look in the left of the image and notice that shiny steel cover/plate with the raised round dimple in it.
That is the metering diaphragm cover.
image three- a strait on view of the metering diaphragm cover.
There should be 4 screws holding it at the corners (at red circles), but as you can see one is already missing from this unit.
Image four- now we have the screws out and the cover removed.
Take careful notice of how that black diaphragm is oriented.
See where the green arrow is pointing at the riveted head of the metal piece?
That will have to be put exactly back the way it is showing here.
Image five- This particular carburetor has two welch plugs (in red circles).
They will vary in size/diameter by the carburetor models that they are intended for.
They sometimes can be made in shapes other than round.
The following tidbit hangs up a lot of folks when they get it backwards!
Also take notice of how the diaphragm is positioned so that it lays on TOP of the gasket (that is still attached to the body).
Notice how the other side of that metal piece (green arrow) looks and how it needs to be positioned when installed.
See how the two tabs/ears (on both the diaphragm and the gasket) fit over the small raised pins on the carb body?
Those tabs need to fit over the pins in order to properly align the gasket and the diaphragm when installed.
legdelimber
10:51 AM
N.C.
P.S. IF you decide to work on the blower for yourself?
Take many photographs as you go.
Starting from before you remove the first part from the blower itself.
And don't forget to stop and make sure that the camera is focusing on the part that matters.
For some reason, (as often seen hereabouts) cellphones seem to be awfully difficult to get focused on the part that we're looking for.
But on another note, We've seen a lot of good shots of peoples shoe toes or else the wall behind their bench! :D
