Decomp MS250
anderson3754
Active OPE Member
3:31 PM
S/E WI
Anyone install or attempt to install a Decomp on the Stihl MS250
Wonkydonkey
Plastic member
9:31 PM
Sussex, UK.
I'm not trying to be smart.. but even a 260 don’t need one .
I know they made a non pro that didn’t have one and a pro that did.
My 036 has one but I only use it if I’ve ran it out of fuel and I want an easy 10 pulls to get the fuel through it.
my 10mm 044 don’t have one
, so I’m not sure a 250 really needs one or has an easy place to install one ( look at the pro & non pro 026\260 cylinders and compare the difference ;)
anderson3754
Active OPE Member
3:31 PM
S/E WI
De-comps they have their place. Starting is easier when the temps are below 20-30 degree and the saw sits outside in the winter. Ref the 260's with new engines, 160 psi comp, the de-comps work nice in cold winter temps.
I just thought I would ask if anyone else attempted to install one on the MS 250's
