Cross Performance 660 top end failure
Heffalump
12:18 PM
NW Oregon
Looks great. What grit do u use on them and what do u hone the cylinder with? Thanks
Jeez Jim that's Purdy. Not much bevel though. ...those run ok for ya ? I'm always worried about not having enough bevel
That is beautiful work!
I can attest, that thing runs like a raped ape.
I tried using it to free-hand cut some half-dovetail notches on a couple of log ends last weekend......it eats the wood so fast I can't stop it at the marks I made!
3:18 PM
So what caused it to hang a ring?
I'll take a stab at this: The Cross MMWS cylinders have wider ports that a stock cylinder, so the bevel on the ports becomes more important in order not to hang a ring (the wider the port, the more important the bevel).
I think several of the Cross cylinders did not come with proper bevel on the downside of the ports, the side you can not see by just looking into the cylinder. I basically checked mine by "feel", and added some sandpaper bevel to top & bottom of all ports as a routine. The old adage, "better safe than sorry".
Wonkydonkey
Plastic member
8:18 PM
Sussex, UK.
So can someone measure them both (farmer-whatever and the cross type) I'd love to know if there's much of a difference
The reason being, I brought a SH ms660 it ran like a hot rod.. Till it hit a nail and buggered up the teeth, then when I showed it some more wood (I was milling) it did not grab/self feed, it over revved an lean seized . (Darn f-words came out of my mouth)
So the bit I'm getting at is, I was not gonna get a new stihl p&c, I got a hyway, it looked good, I slapped it on and took the othe p&c off to find it was an AM p&c with 1122 on the side,
I was still pissed about the whole thing, I tried to clean it up and thought it's junk and took a pic or two, and tossed it in the trash.
Then I joined this forum,
I now relised it was a ported am p&c , and I should of got some timings from the jug Doh....
Now I got a lovely hyway and it don't go like the last one did..
Still there's no chance of me lean seizing it again as I turned up the Hjet.
Wonkydonkey
Plastic member
8:18 PM
Sussex, UK.
See my Flying Tiger thread in the Chinese 660 section.
I've been following every build in the rice burner sub forum, not just yours
I ve got a ms 660 and liked it !! Before I lean seized it.. Now it's got hyway ummm.. Good but not as good....now i a want a clone as well, to play- port -mod etc,
So I've been following and learning, but the porting is still a bit of an unknown, although I'm getting the hang of timings. Which has been good to hear all the numbers in each thread and the vids of the saws working
Like I said, I wished I'd known what my last AM timings were on my 660 and that id kept it to compare,
But that's been binned now it's read and read some more
Cheers
Keep up all the good work,
3:18 PM
I posted some port width #s on an 066 thread, I will have to look and find them again. The ports on the Cross MMWS are wider than stock.
3:18 PM
OK, I found my notes on comparing the Cross MMWS #1 (#2 is on Fyling Tiger) to the OEM 066 cylinder, which ran very well.
Cross Intake approx 1/16" wider, Exhaust approx 1/32" wider, Exhaust is lower, Upper Trans about the same, and Intake Opening is lower.
On the Cross #2, the Exhaust was lower (than #1) and the Intake was higher.
This is a copy of my measurement paper (OEM, C1 (first Cross), C2 (second Cross).
Wonkydonkey
Plastic member
8:18 PM
Sussex, UK.
That's 1 heck of a way to advance exhaust timing with the piston
Can you explain a bit more, for my not so bright brain, ? Is it there's a small but big difference in Pistons and therefore timings changed
:nusenuse:
bikemike
2:18 PM
Cottage grove mn
:nusenuse:
Yeah look at the exhaust port. The top of the piston is is allowing the exhaust to start opening before the piston has even cleared the exhaust port. It was a sarcastic comment cause some of the top is gone
Wonkydonkey
Plastic member
8:18 PM
Sussex, UK.
Ar I see, doh silly me. :rolleyes: :qmeparto:
