big_billings
- 5:29 PM
- Aug 11, 2019
- Haliburton Ontario
Does anyone here have a 250r case in good shape? Starting to get parts together for a bike saw project.
I verified with Willard on his build the 83 cases are way off!!From memory if you want to run CR cases with the trx cylinders you want 83/84 range?
So what year is the best to put a trx head on ?I verified with Willard on his build the 83 cases are way off!!
I think the 85-86 are be best cases for the trx cylinder. 92-01 cases are great, and the esr 330 cylinder is available now, the 97-01 ignition is perfect and simple and obviously a bolt on. It’s a great way to go. Stock an 01 makes 48hp to the wheel, flywheel hp is more, a 330 esr cylinder is capable of 60hp+So what year is the best to put a trx head on ?
I wanted to put a saber tooth kit on a trx case
my buddy is saying he is going to pull the trigger on pantera motor...linger 550, should be coolI wanted to put a saber tooth kit on a trx case
I haven’t run one of those, I have build all of mine as dunners, thous cylinder would be interesting, they take a lot of work to run hard, but might make great dunners. I would love to try a bunch of builds, I want to try so much! There are a lot of optionsI wanted to put a saber tooth kit on a trx case
There are lots of options!! LolI haven’t run one of those, I have build all of mine as dunners, thous cylinder would be interesting, they take a lot of work to run hard, but might make great dunners. I would love to try a bunch of builds, I want to try so much! There are a lot of options
Would you be willing to sell that motor or know a place I should keep my eyes on for a bottom end?If your wanting to start out 250, the 92-01 is a great platform you can mix and match the best stuff and all the cylinders are plated , and. 330 is available from esr.
I have a rare 01 Cr250/330 pro-x cylinder non powervalveView attachment 210575
