SteveSr
- 3:53 AM
- Dec 14, 2016
- North Carolina
![United-States Country flag](https://opeforum.com/data/files/flags/shiny/32/United-States.png)
Hello,
Well, after just wasting an inordinate amount of time because I don't have a good compression tester it is time to replace the KD tools POS I have that consistently reads really low and it even has a non-changeable Schrader valve in the tip.
I am looking for something that is accurate with small engines and won't break the bank like the truck vendors. The specs don't usually specify Schrader valve in tip or the extra volume it adds to the compression chamber which lowers the reading affecting accuracy.
Here are the contestants in no particular order:
Bosch - Owatonna (OTC) model-5605 or 5606
https://www.otctools.com/products/compression-tester-kit
Made in China. Don't know where the schrader valve is. Looks like the fixed long hose on the gauge could mean a LOT of rope pulling to get maximum pressure reading.
ATD-5639 / Lang Tools TU-30A
https://atdtools.com/5639
http://www.langtools.com/sku-tu-30a-compression-tester-set/
Country of manufacture is unlisted. Does anyone know which (if either) of these companies is the actual manufacturer? The photos look pretty much identical except the ATD comes in a red case and the Lang comes in a gray case.
Location of the Schrader valve is unspecified. Extention hose is optional which would make for less pullling. This set also has a dedicated small engine gauge (TU-21) with the Schrader valve right in the tip. The gauge looks sort of cheap and it won't do the newer 10mm plugs in 4-mix engines without a compression lowering adaptor. Will a Schrader valve even fit in a 10mm spark plug footprint?
Does anyone have any personal experience with any of these testers and could help fill in some of the missing information? I haven't done a lot of price shopping but it doesn't look like there is much of a price difference between any of these.
Thanks,
Steve
Thanks,
Steve
