Cobbled mini atv clutch issue
BuckthornBonnie
7:54 PM
Penn Yan, NY
My buddy grabbed a cheapo atv with problems. Someone chopped up the frame and put in Briggs 5.5 ohv. It runs (thanks to carb rebuild, oil change, valve adjustment) but the clutch is fried.
It’s a keyway clutch shaft (not a spline) that is 14mm at the end. The original clutch shoes/pads are shot.
Is anyone into these things? Any options to make an eBay clutch work?
Wagnerwerks
7:54 PM
Pa
I had one of the 5hp go carts with the comet. They work very well. My son drove it into the ground and it would pull us both around without issue. They're so cheap on ebaeit makes me sick after rebuilding an original...
redline4
I'm huge in Japan
6:54 PM
Rosholt Wisconsin
Try BMI kart also.
Is that the shaft the clutch was on? On the jackshaft, not engine crankshaft?
When I was racing mowers there were 2 different classes that allowed centrifugal clutches. Some guys ran them on the crank, some on the jackshaft.
Comet Kart or EC distributing could also likely come up with something, but the clutches they carry are meant for more HP, and not cheap.
BuckthornBonnie
7:54 PM
Penn Yan, NY
Yep, the clutch was on that jackshaft. Good to know about other options.
Yeah, this needs to be a cheap fix. It’s already cost a lot of time just figuring out what the heck it is (still dont know brand or anything). It’s pretty much a death trap...
BuckthornBonnie
7:54 PM
Penn Yan, NY
No dice on any current production clutches fitting. Looks like we’ll need to make a sleeve or try to repair the old one. The shoes are totally shot, though.
redline4
I'm huge in Japan
6:54 PM
Rosholt Wisconsin
Couldnt you just use a different jackshaft? As long as the o.d. of tbe bearings are not some strange size, new bearings and a normal diameter jackshaft should cost too much.
J_M____
7:54 PM
CT
You can see if you can find a place that still relines brake shoes in house. They may be able to rivet on new material
