Cleaning ext. enclosed trailer help
echobite
OPE Member
10:36 AM
West Mi
I was wondering on what type of cleaner product people would use when hand scrubbing? I will be renting a power washer. I don't think a power washer is going to remove all of this scum on the trailer. If I can remove all of the scum I might polish the trailer too.
Motorka
4:36 PM
EU
Philbert
Chainsaw Enthusiast
9:36 AM
East Dakota
I like the idea of trying a car wash first, maybe to remove a lot, if not all the dirt / scum / whatever.
SuperClean and LA Awesome each have sodium hydroxide (lye) in them, whis is good for removing grease, but not for aluminum, or some paints.
Is is mold? Algae? Dirt?
I would visit a few home centers, and auto supply places, and read the labels on the various cleaners they sell.
We’ve used the pump-up, garden sprayer type things to apply mold abatement chemicals. The ‘chemical resistant’ models are about $5 more.
Then use a large sponge, and sponge mop, to clean with a minimum of scratching.
Philbert
They call me Mr. Kibbs
10:36 AM
Wandering the VA woods
Never done it on a trailer, but I clean our white aluminum gutters with a pump sprayer and 80/20 mix of cleaning bleach and tap water. Spray an area, let it sit until it turns white (+/- 5-10 min), then rinse with garden hose. Be sure to rinse before it dries. If really nasty let it dry and do it a second time, it's about as easy as it gets.
On the north side of the house we get some mold (or mildew, I don't know) and some residue from the wood stove chimney, cleans it right back up to bright shiny white.
CAUTION-do not just use any old pump up sprayer, bleach will eat up the seals on those not intended for it. Home Depot sells a bleach sprayer for about $20-$25.
You can always do a test run with bleach from your laundry room and a wet rag and garden hose...pretty cheap
Dustin4185
10:36 AM
East TN
Scott’s plant safe outdoor cleaner or RV cleaner. I e used both and never had an issue with it hurting the aluminum. Of course the RV cleaner is designed for painted aluminum siding.
Boomer2230
11:36 AM
Canada
Look for a Hotsy dealer close to you. You either want Carbonate or Breakthrough. They can both be diluted with water. Best results with hot water.
I started using Carbonate back in the 80's.
Sloughfoot
7:36 AM
Norcal
Philbert
Does diluting Super Clean keep it from doing that?
Philbert
Chainsaw Enthusiast
9:36 AM
East Dakota
I don’t know.
I try to start with less harsh chemicals first.
‘PurplePower’ does not have sodium hydroxide. Neither does Simple Green. So these might be better cleaners to try first.
If it’s mold or mildew, there might be specific cleaners designed for those. I have used some on wood (gentler than bleach), but don’t know how they work on aluminum, of paint.
I am a guy who calls those ‘1- 800’ numbers on the backs of the containers in the stores, and sometimes have had very helpful, informative conversations with the technical reps.
Sometimes not (!), but it’s free and worth a try.
Philbert
jmester
10:36 AM
VIRGINIA
I have had good results using soft scrub with bleach. Not on a trailer but on a truck cab. That had moss,mold and mildew or whatever that stuff is that grows on them.
