Chain comparison
StihlEchoingHusky
12:24 PM
Anyone have a picture of 3/8 or .325 pitch chain next to 3/4?? I can't seem to word it correctly for Google to understand 😂
hacskaroly
2100 Fanclub Member
12:24 PM
Northern Idaho, Ehh
If you want something on hand, you can order this Oregon chain scale sticker, it compares the different sizes and if you mount it to a bench, it helps making chains easier, especially if you put a peg in the table on the left side, connect your chain to it, drag it out and mark the driver you want to punch.
Edit: Sorry, this is the clearest picture I could find off hand. Goes in order from top 3/4, .404, 3/8, .325, 3/8LP, 1/4.
9:24 PM
PA Dan
FYD
3:24 PM
White Oak PA
Here is 3/8P, 3/8 and .404.
heimannm
2:24 PM
Dike, Iowa
The big chain in the lower left hand corner is 7/8" Adkins harvester chain, each cutter is an individual forging.
I don't have anything capable of pulling that chain...
Mark
atpchas
12:24 PM
Napa CA
Curiously, the rivet diameter on the 7/8" chain appears no larger, maybe even smaller, than that of the much smaller chains.
Bill G
2:24 PM
The 7/8" chain was ran on the Von Ruden direct PTO powered saw. There are several folks with the hydraulic powered VonRuden but i believe those take a smaller chain. The hydraulic ones used a PTO hydraulic pump, The direct PTO powered ones are driven by a PTO shaft. I have one but I have never had the testes to run it.
EFSM
2:24 PM
Extreme southern IL
Yes, it does look small, but I think it must have shouldered rivets, maybe even something carried over from roller chain. The hole in the drive link looks larger than the spun end of the rivet.
