Cdi ignition module for echo cs510evl
zgzmithr
Active OPE Member
6:21 PM
NC
The part number for the CDI ignition module is 15660118330.
The part number for the ignition coil is 15662618330.
This is an obsolete part, but I am working on a very nice cs510evl and I desperately need one.
This saw has a separate ignition module and ignition coil, The ignition coil test out to the specs (almost, but the primary resistance is off by .5 ohms) in the service manual. But the service manual States if no spark is found after testing the ignition coil, then replace the CDI ignition pickup. (But I would like to replace both with a known working pair)
Nos or used and operational is fine with me, please let me know if you have one.
