jomeza001
New OPE Member
- 10:17 PM
- Jun 16, 2024
- Mkt$9386950235730
![United-States Country flag](https://opeforum.com/data/files/flags/shiny/32/United-States.png)
I need help diagnosing this Scag Zero Turn Mower with a Diesel CAT C1.1 3 cyl Engine and a 72 in Deck
I have checked the blade spindles and all are spinning freely.
It's got three problems:
1) It fires up real quick and feels strong while cold. When Temp gauge reaches half it loses power. Then Temperature reaches the red zone so I have to shut it off but motor is very very weak.
i already have replaced water pump and Thermostat. Still temp gauge reaches the red zone.
What is causing to overheat??
2) Within 15 minutes of using it there is already water in the diesel Filter. I had to install a diesel water separator to be able to drain the water easily. So every time I have to stop the mower and drain the water. The Diesel I use to refill the tank is not contaminated with water. And I have drained and meticulously dried the inside of the diesel tank twice in the past. Still I'm getting the same issue.
What is causing the water problem?
3) When I fire up this mower the Oil PSI is perfect, gauge reads half way. However when the Mower gets warm the Oil PSI drops to 10-12 PSI. When the Engine gets real hot the Oil PSI drops to ZERO even if at Full Throttle. I have replaced the Oil PSI Sensor.
Why causes the Oil PSI to drop?
Thank you all in advance for your help.
