WoodAbuser
- 12:21 PM
- Oct 8, 2019
- Minnesota and Iowa
Why?.....................I do not recall when I last knowingly ate beef.![]()
Because we tend to buy poultry & pork.Why?
I rarely eat chicken and much rather eat beef than pork. Lamb is a bit differentBecause we tend to buy poultry & pork.
(Not) Scraping By
Wanted to protect my stacked cookware. Not just seasoned cast iron, but enameled, non-stick, etc.
New pans are often packed in corrugated cardboard, so I started with circles of that (like mini-pizza trays), or pieces of old towels.
Found some silicone ‘stars’ on clearance at a fancy kitchen store (red in photo), but regular price was ridiculous. Same with heavy, felt ones.
Settled on some thick, rubber, shelf liner material from a home center. Made a pattern out of a piece of cardboard.
Will see how they work?
Philbert
Takes off everything leaves raw cast ironVery nice!
This is electrolysis? I’ve used it for rust, but did not know it took off old layers of seasoning.
Philbert
I got ‘spooked’ trying it on a rusty chain: blew a bunch of chrome off!I use it for rusted chains and bars as well
Reversing the anode and cathode (polarity) is used for plating, so I would expect using it the way folks do for cleaning would remove plating.I got ‘spooked’ trying it on a rusty chain: blew a bunch of chrome off!
I assume that the rust hand penetrated below the chrome, but still been a bit gun dhy of trying it again.
Philbert
I did not do that to my raw cast iron firepot and when washing I notice sharp edges and small bumps.FINISHING
A lot of cast iron has sharp edges along the rim, etc., along with occasional sharp spots in the cooking surface, that you feel when cleaning.
This is a pet peeve of mine, especially, around the handles.
While stripped, I tried a number of abrasives, that I had, to smooth some of these out: sanding discs, abrasive cloth, Dremel sanding drums, stone points in an electric die grinder, etc.
Most worked. Some faster than others. The Dremels and die grinder were easy to control for detail work, with the piece clamped to a table.
3M ScotchBrite, Roloc discs worked really well, but can be harder to find. A straight or right angle pneumatic grinder could also be a good option.
The hanger holes and Dutch oven handles were a bit trickier. I used some ‘dull’, 5/32”, round, chainsaw files to reach tight radiuses, then finished with abrasive cloth, pulled up-and-down against the edges.
The photos also show a coarse, ScotchBrite, paint stripping pad in an electric drill, used to smooth down the ‘stipple’ of some newer cast iron: someone started that on these pans before I got them, and I will cover that in a separate post.
Philbert
