I have an Echo CS 302s that has a walbro wa 5 on it. I can't for the life of me get it right. Does anyone have any idea what alternative carb would mount up correctly on this saw? Finding a used one isn't easy.
Ok thanks. I will start with double checking everything else. I will need to pressure check it too.
the saw idles ok. And once in awhile it will rev just fine, but most of the time it falls flat.
