HELP! Cam Shaft in. Briggs & Stratton 24hp V-twin Intek
Stoa25
New OPE Member
1:38 PM
Chanhassen
I just got back from visiting my elderly father. While I was there he asked me to help him with his lawn mower. It was “hanging up” occasionally (nearly every time he turns the key) when he tried starting it. I adjusted the valve lash but the motor still hangs up. I’ve replaced cam shafts in similar motors due to the compression release mechanism failing. I’m seeing conflicting information online on whether or not this specific motor has a compression release mechanism. The model number is 445577, type 0435 E1. 24hp v- twin Intek. Can someone with much more experience that I have tell me if this motor has compression release mechanism? If it doesn’t, and the valve clearance is within specs, what else would cause it to hang up?
farminkarman
I like the red & black ones
1:38 PM
Neenah Wisconsin
I would assume it has compression release unless you find otherwise.
EFSM
1:38 PM
Extreme southern IL
Yes, this does have ACR. To my knowledge, the only B&S that don't are the big block Vanguards. I've never seen one fail though; they are way more reliable than the single cylinder engines, which fail routinely. You should be able to see the exhaust valve bump open on each side when the piston is nearing TDC on the compression stroke.
