Sawponder
- 11:38 AM
- Mar 11, 2024
- Virginia/N.Carolina
Trying to figure out what size crank bearings are in this blower. I believe it is a 6302 with 16mm inner diameter (rather than the usual 15mm)
Both blowers had tiny bit of radial play from crankshaft ends. but the bearings arent press fit they just slide onto the crankshaft, and also just slide right into the bearing pockets....so im wondering if a bit of radial movement is okay in this case?
