Bg86 running probably
Tom hadlow
Active OPE Member
8:10 AM
Uk
I have a bg86 that run fine when in an upright position but as soon as you change the orientation of the blower it will stole out I have pressure vacuum check it and all is fine I have also checked the whole fuel System (fuel line filter tank breather) and pressure test the carb I am really stumped in what could be the cause of the problem any help is much appreciated thanks tom
DND 9000
9:10 AM
Germany
Maybe a damaged insulation on the short circuit wire grounding it? Also check the high tension cable for the spark plug for damages.
Chuckiet3
2:10 AM
Antioch, IL
mine was running wierd and it ended up being the spark arrester in the muffler being blocked with oil residue. I unscrewed the arrester and burned off the buildup and she runs like new.
