Best compression tester for small engines?
Saw Collector
OPE Member
11:07 PM
Here
Wet as in a cc of oil in the plug hole and pulled over a few times to lube the cylinder.
whitesnake
11:07 PM
NY
The echo kit come with enough adapters for all small engines?
EFSM
10:07 PM
Extreme southern IL
That looks like a real good one. How many different sized threaded spark plug holes will it fit? Obviously all the Echo stuff.
Just about everything of all brands. I know of no other threads that are used except for some weird Kohler engines (IIRC 12mm). The B series NGK plugs (C series Champion) are 14mm and the C series NGK (D series Champion) are 10mm.
