Best 16" bar, pitch,&chain combo for ported 550xp
Willard
6:17 PM
Manitoba
Bumping this old "best 16" b/c for 550XP" thread.
I cut and remove alot of spruce in my area and in the smaller stuff I setup my 550XP with a 16" .050 3/8" bar cut down to 14".
Replaced the dogs with a smooth bumper and the best chain is....Stihl 33TS (Topic Super) and Oregon 76 LG.
Beautiful smooooth, strong and quick cutting 3/8" chisel chain NLA that doesn't require a Picco or LoPro bar or sprocket.
I still have quite a bit of the chain in both brands. Bigger then a .325 but smaller then a standard 3/8 chain. Yes as pic shows back in the 1980's chain out of the box didn't have alot of sideplate angle. Enduser had to file that in himself.
I wish they'd make it again.
Willard
6:17 PM
Manitoba
A well ported 550 will like 3/8's chain. It's more durable and can clear chips better than lopro.
As I said with my example in my above post my 550XP was setup for small limby spruce with a 14" bar and 33TS and 76LG chain. Didn't need to be ported either.
Here a pic of a full size 3/8 cutter on my 76LG chain.
40 years ago I built my race chain on a 76LG chassis with all full size 3/8 cutters, I called it a 3/8 High Tooth chain.:D
Willard
6:17 PM
Manitoba
Unfortunately I sold my 550 last spring , I can do everything it can do with my 562XP.
Back in the 1970s, 1980s and early 1990s our logging company made us fallers use 9 tooth sprocket nose safety bars like the Windsor Mini Pro and Oregon banana and PowerMatch DoubleGuard bars to reduce kickback injuries with our short 16"- 20" bars. We were running these on 034 to 064. 630/266 to 920/288 saws.
We'd run 33RS/72LP-LG chain on them but in smaller limby spruce they'd derail easily so we ran the smaller 33TS/ 76LG chain that didn't have a problem derailing on these small radious nose bars.
Here's a pic of a 30 year old 16" Windsor Mini Pro bar I sold with my 550XP last spring.
Last pic is a 35 year old USA made Oregon 5mm file that I filed the 33TS/76LG chain with. In between size of a 3/16" and 13/64" file. Made better chip clearance and chip flow on those lower cutters. Best quality file I ever used and still have cases of them from collecting over the years from auctions etc.
Willard
6:17 PM
Manitoba
I love this pic. Unbelievable how many people today still don't know how we did this over 40 years ago.
One of the best kept secrets building race chain:applaudit:
Hedgerow
6:17 PM
Eh.. Sort of a secret..
I still see a few here and there.
I've got some loops that are stamped Mac..
Willard
6:17 PM
Manitoba
Yep you and I know there are a few of us who remember from the old days.
370 Mac rebadged 76LG. Or is that the chain Homelite/Sabre tried to market after trying to copy Oregons patent by buying a few thousand feet of Oregon's 76 chain ?
Farmchuck
7:17 PM
Nepa
I recently came across a quantity of
34LG chain in 66dl loops. So it looks like that will be my set up for the foreseeable future. I am enjoying all the insight into what everyone else is using. It is most educational/enjoyable!:)
Farmchuck
7:17 PM
Nepa
It does cut quite well other than the fact that a lot of the pole wood I got this year is pretty dirty what with all the rain we’ve had in or area.:hmmm:
CR888
11:17 AM
Hey Willard, how did the combination of high tooth & low tooth in full house sequence cut? Did the low cutters bite wood or go along for the ride?
Willard
6:17 PM
Manitoba
CR888, I didn't explain what I did there very well. When I took that pic of the chain I was just demonstrating how the full size 3/8 cutter fits on the 76LG chassis.
When I used to built my race chain I would replace all the smaller 76LG cutters with the big 72 cutters. So what I ended up with was a "high tooth" 3/8 cutter chain thanks to the lower 76 chassis.
Better chip clearance and flow and the chassis still retains its full case hardened links for strength.
CR888
11:17 AM
OK gotcha. You may find new love for the 550 when you see the new changes that are coming. They are gaining a little weight but are refined for reliability. They have a new darker grey clutch cover.
