- 3:32 AM
- Dec 30, 2015
- Brewster, NY
I used my HF bearing puller for the first time today on the 034 crank. It is the first time I have split a case and removed bearings. The flywheel side bearing was fully in tact, and came off uneventfully.
On the clutch side, only the inside race remained, and it looked like it had moved close to the crank, not giving much, if any, space to insert the remover, but I put it on any way. I was getting the claimshell part of the puller fairly tight and the bearing was not moving, so I plugged in my heat gun and warmed it up a bit.
I'm embarrassed to say that when I did this, I pointed the stupid thing right at me. Luckily, when I got done with the heat gun I spun it in the other direction and continued to tighten the nuts. The damn race shot off like a bullet, and a piece of it even broke off and ricochet around the garage.
Lucky for me, it was pointing away from me. So my advice, (lesson learned, and I got lucky), always wear proper eye protections when removing bearings, and always keep it pointed away from you in case yours "shoots off" like mine did.
I lucked out guys, so I hope no one else makes the same mistake I made.
