FergusonTO35
- 7:21 PM
- Jul 9, 2017
- Boonesborough, KY
So I'm working on the father in law's push mower with a 2015 Briggs 450E and intermittent no spark. I'm thinking the coil is going out. Reason being, the wire connector tab on the coil that goes to the oil switch always has continuity with the rest of the engine. As in, take the kill wire completely off, touch one DMM probe to kill wire tab on coil and the other to the engine and the continuity buzzer sounds continuously. So my thinking is, this metal tab on the coil should never have continuity to ground unless the kill wire is attached and the kill switch is engaged. If it always has continuity, then what difference would the kill switch make? Or am I just totally misunderstanding what things here?
B&S engine 08P502-0063-F1
OEM coil part number 84005272
