Redbull661
661 hoarder (BlueBallz)
- 3:23 AM
- Dec 31, 2015
- wisconsin
Special thanks to @Ryan Browne for letting me test on his frozen ash wood.
These are the two chains I am considering running on the 661 41". I wanted to see the differences in cut speed and but mainly see how hot the saw got with each.
Up to this point on what I was getting a sense from watching the thermocouple that jug temp depended more on time in the wood then it did on the load on the saw. Both we're important. But it was seeming that time in wood raised the temp more.
Figured I best test it specifically cuz well you know me! lol Sooo this doesn't seem to be the case. The 404 took much longer but really wasn't that much hotter...relative to how much longer it took. In other words I was thinking if it took an extra 7 seconds that temp should be much much higher.
Tree Monkey'd 661R Arctic, 41" Cannon.
7 pin 3/8th 128dl - Stihl semi skip square.
19.3 366F , 20.3 426F
next did 8 pin 3/8th 129dl - Stihl semi skip square
18.0 371F, 20.3 422F , 20.2 428F
next 7pin .404 117dl - Stihl full skip sq.
25.3 399F , 27.1 443F
