A/T recommendations
Dustin4185
2:24 AM
East TN
Thanks for the suggestions. I used to run KO2s on my half ton Ford and they always did great. I had the dealer put them on when I bought this truck and they didn’t wear like they should have. I went to Coopers AT3s when they first came out and wasn’t a fan of the traction. These Grabbers have been my favorite by far.
furb
2:24 AM
PA
My AT3s were always sketchy for traction. I came out of the turn where the flares are. I was barely on the gas. Those tire tracks are from water being tracked out of the puddle on the turn and turned to ice right about where the black marks start. The truck went sideways so violently it took the outside of the right rear tire tread off at a 30 degree angle. I might have been going 25 mph. I think a better tire would have grabbed and flipped the truck. I about sharted. I slid between a pole and a bunch of mailboxes and ended up perpendicular to the road. I’ve never laid rubber with all four tires before.
maulhead
12:24 AM
Home
I really liked the last two sets of Falken Wildpeak at3w, I had.
But wanted to try some strange, so I bought a set of, Maxxis Razr at's.
I have not had them long enough to form a opinion on them.
I strongly dislike BFGs, had them on few trucks, they don't last for *s-word on heavy trucks, I think they are over priced.
amateurarborist
Active OPE Member
12:24 AM
Idaho
Grabbers are good but they get weird in certain lt sizes if you haul a lot of weight. You’ll see them roll around on the sidewalls. It might have been a short lived issue but there were some sets swapped out and the distributor gave credit for them. I like them. I’ve run them on my crvs and rangers. The hankook dynapros are another good option. No experience with the toyos but people seem to like them.
This post made me think of another important consideration. Once you almost have a tire chosen, check the specific sku on the manufacturer page and look at tread depth. Some sizes, especially in the Hankook dynapro, will only be 12/32 new (we wore those out fast). You want to see 15/32 or greater. Otherwise it's basically only going to act like an AT tire for half of its life. At that point it's a street tire that looks like AT because the tread is so shallow. If you need to use them on dirt or snow, this is important. I found the hankook dynapro to be very soft rubber and wore quickly.
