Cerberus
Cerberus the aardvark, not the hell-hound!!
- 10:17 AM
- Jan 20, 2020
- Florida (tampa area)
TL;DR-- What type of piston do I need to get for a kit-660, whose original piston was a flat-topped, 53.75mm 2-ring? Squish was ~0.024" I think.... Also, do I need to order specialty tools? I'm not naive to engines I ported my 590 last month and do my own work, just have never worked with a piston or bottom-end, thankfully everything else looks OK except the squish-band but I expect that'll be a simple fix w/ drill or dremel!
^think that can be buffed-out?
LOL seriously though I wanna ensure I'm not only getting the right 'size&type' piston, but don't wanna get a cheap one and need to do it again shortly... Re piston size / squish, I'm quite sure this saw's cylinder is machined, the piston-top machined, I know the cylinder base was cut, should I be worried that if I get a piston, and "size things" by setting squish via base-gasket thickness, should I be worried of throwing port-timing outta whack enough to be a problem? I mean, if I hurt its power 5% I can live w/ that, but if I should be getting a piston and cylinder I will, reallllly wanna keep this cylinder though, was done better than I could ever do!!
This is a kit-660, incredibly well-built w/ very high % OEM, so - when I discovered that my anomalous failure-problems were due to the piston having been chipped, it was nerve-wracking getting that top off to see just how bad things were....thankfully it seems my cylinder is nearly perfect (squish band got roughed-up, should be able to refinish that with the drill or dremel, heck I can get my long-shaft die grinder in that cylinder!) Bottom-end also looks great although wanna have you guys look at this picture because I worry about that spot on the rod, where the piston's arm connects, that spot is 'see through' to (bearings?) below, but it doesn't appear the metal was damaged it appears it should be that way, just hoping for others' eyes on it!
Ported, dropped-deck and machined-chamber(99% on this one!) cylinder appears very salvageable, just the squish-band in the comb.chamber seems affected and A) that doesn't need to be perfect &B) it's easy to smooth-out & refinish that, especially in such a large cylinder, I have drill / dremel / die-grinder am sure I can polish a surface, am happy w/ the port-work I did on my 60cc!
Plating, not so bad: (excepting above exhaust-port!)
Combustion chamber's squish-band certainly needs refinish, but shouldn't be hard:
Though I guess, from the right angle, the plating isn't looking so shiny at all spots (this seems limited to exhaust-side, above-outlet plating only, unsure how much of a problem this presents, I do have virtually every dremel/drill/grinder attachments possible!)
NOTES/Thoughts/Disregard
Reallllly worried about fitment of a modded cylinder, w/ a "stock size" piston, hate the idea of losing the custom ported cylinder BUT if it's the quickest and most reliable way back to this guy being in working-order, that is first&foremost for me (I can probably pay&ship to recreate any cylinder/piston, and simply replace after...I'm OK "buying into" this platform and having extra parts, do not plan to leave it anytime soon!!)
I made a video to show things as well, will link here:
Am new to this platform but just totally in-love with it, before I had the top off I was ready to order a blue thunder g660 if I found the bottom-end all destroyed, would just swap-over all my superior parts and go from there, I just can't see any reason to leave it / can see why it's such an iconic saw (will have a 661cm someday!!!)
