630 super intake
MinnesotaJon
10:58 PM
Grasston
Does a 630 super have the same intake block as a 268? Looking at a scored one. Thanks!
82f100swb
10:58 PM
Dryden, ON, Canada
No, the 630 uses the same block as a 266, bolts on the cylinder, then the carb bolts to it, not through bolted like the 268/272.
MinnesotaJon
10:58 PM
Grasston
Thank you I thought this was on the 61-272 chassis. If I can get it cheap enough I will still probably pick it up.
82f100swb
10:58 PM
Dryden, ON, Canada
Yes, the 630 is a 162 chassis saw. It's more or less a continuation of the 162 itself, it uses the same 48mm bore, closed port cylinder.
I know the 266 cylinder will fit under the filter cover, not sure about the 268, but I believe you will have plug clearance issues with a 272 cylinder.
Unless it's a very late Super, it most likely is a dual coil saw.
